CL-Class (W215) 2000-2006: CL 500, CL 600
replace spark plugs
Old Mar 24, 2018 | 04:35 PM
pmercury's Avatar
member
CL
Exclamation replace spark plugs
I now have a absolute 0 ignition fault
remember, if you have a very tuned engine, your sparks have to be replaced twice as fast
Seafoam your engine with the old sparks if you want the engine somewhat carbon clean
ONLY use
A0242236571 Bosch fr7ki332s
Keep your hand off the irridium pin, do not measure them with a metal blade !
they are made for the V12 biturbo CL600 and AMG CL65
preset is perfect
First, remove intercoolers, air filter
then remove the coilpack
spray W40 where the plugs are, wait 15 min
blow with air
Spray where the spark holes are again with break cleaner, plenty
blow the crap out
remove spark plugs
remove the red isulators
check, clean or replace
then use ONLY
Mercedes-Benz Spark Plug Grease - A0029898051
I show the limit where to put grease and how
replace spark plugs
done
NGK spark plugs suck for this car
I blow all in 8 month's
good luck
