CL-Class (W215) 2000-2006: CL 500, CL 600
CL600 Starter Replacement. How the heck do you get to it?
Old Apr 15, 2018 | 06:12 PM
AustinV12's Avatar
CL600
Followed the MB manual on replacing a 2001 CL600 starter. Dropped the bottom panel. Took me 10 minutes to even get a glimpse of the starter. Lots of ABC assembly between me and the starter. In order to get to the attached view of the starter, you'd need to remove the wheel well, heat shield and then some.
YourMechanic has quoted me about $600 to come and do it for me. Thinking that might be the deal to take, unless someone out there has a trick (probably several tricks) to share.
Thanks.
File Type: pdf
Old Apr 16, 2018 | 03:51 AM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Wis has it about right.
Once you drop the exhaust there is enough space, its not too bad.
Remember to detach the battery.
Old Aug 4, 2018 | 06:36 PM
AustinV12's Avatar
CL600
I let the mechanic handle the starter. Took him two hours. Probably would have taken me 6-10. Car now starts every time, but am still working through intermittent Limp Mode foolishness. Thinking its a prolonged relearn issue (lots and lots of new parts), but sure would like to make that isue go away.
Old Aug 5, 2018 | 04:15 PM
Originally Posted by AustinV12
I let the mechanic handle thhhe starter. Took him two hours. Probably would have taken me 6-10. Car now starts every time, but am still working through intermittent Limp Mode foolishness. Thinking its a prolonged relearn issue (lots and lots of new parts), but sure would like to make that isue go away.
Any codes?
Old Aug 5, 2018 | 05:33 PM
AustinV12's Avatar
CL600
No CEL. No codes. Pending codes for both Camshaft Sensors and associated O2 sensors. Put it through 8 start-up cycles today with no Limp Mode issues. Hopefully getting better every day.
Old Nov 19, 2021 | 03:06 PM
benzboy1989's Avatar
cl600 sl500
Thanks.
hey brother I’m having some issues with my 2002 CL 600 sometimes it doesn’t want to start starter doesnt engage or do anything... if I wait a few hours it starts. Did u have similar symptoms? What symptoms did u have?
