Cl500 Tires and Rims question
cl500,c300,c240,e320
Hello everyone Hope you doing well , Ihave question about tires size and rims .. my car 2002 cl500 Right now i have set of Amg rims on it which is 19” with 235/45/19 tires front and rear , my question is it okay if I keep them ? Because tires manufacture recommended size 225/55/17 front and rear , i,m also having harsh ride I do have 18” amg rims can I put them and what’s the tires size should I go with ? thanks
Yes, you can keep them.
They will be harsher than 17s or 18s...but they look well (unlike the stuck on vents on your front fenders).
Very rare to see two 215s living so close to each other.
In my experience, it is less the size of the wheels or tires than the ride qualities of the tires themselves. I went from 18" to 19" recently - with different brand and model of tire - and the 19" are far superior. Basically, use the wheel size that you think looks best, then size the tires so they don't rub :-), and choose the brand and model of tire based on reviews of ride and handling. Tirerack.com is a good source - but not necessarily the correct answer for you.
Of course, if it's for track use or if unsprung weight and/or handling is your primary objective, you will have a different set of questions to ask yourself.
vents came with car ..
you can fit many sizes from S600 to CL65 ect
but you are supposed to set the new size in Engine ECU with DAS Developper ONLY
as I show here, all 4 wheels have a different parameter
19 inch is far the best
rear
DUNLOP Sport Maxx Rt 2 275/35R19
front
DUNLOP Sport Maxx Rt 2 245/40R19
far the best tires I tried, and I tried them all
Only Pirelli P0 are superior but you smoke them too fast
rear
front
biker349 (05-23-2018)
