CL600 slowly rises, is the hydraulic valve on strut?
So this had my curious, is the valve that controls the hydraulic fluid in the strut itself or is there a distribution block I need to replace?
The struts were all done 1.5 years ago and the ABC pump is under a month old as is the line that goes to nowhere. Is there yet another part I have to replace or do I have to replace that passenger rear strut again? Also since the system runs at nearly 3000psi what is the proper way to relieve pressure before replacing the part?
I was just reading your post. Just purchased an 2002 CL500. I have a few questions.
Is there a valve assy for FRONT shocks and REAR shock?
Did you replace the seals yourself?
Where are the valve assemblies located and how did you bleed the system.
Thank you
