CL-Class (W215) 2000-2006: CL 500, CL 600
CL500 ABC issue
Old Feb 20, 2019 | 12:31 AM
knowbenz's Avatar
Benz
Originally Posted by Yuki18
I got a 2002 CL500 and it leaves the front side a little higher than the back and the rear passenger side is about a inch lower than the driver side, I thought this would probably be a sensor because it’s obvious there is no leak and the oil is full and clean. Do you think this would fix it and did you ever fix yours?
I would hook up SDS and check actual values of vehicle level. If all is even then make sure no level sensor arms are bent or installed improperly. You can level it all up and calibrate ride height as well.
