Front side turn signal access
That is what I did and replaced the bulbs on both sides, however they still don't work. I have been trying to figure out next if there is a fuse I can replace for them, but I cannot figure that out. The chart I saw simply says it is an electronic fuse, but does not indicate where it is.
Any other suggestions would be appreciated.
The parallelogram shaped lights on the front side of the car can be accessed by taking a flat-bladed screw driver and taping the tip to protect the paint on your car, then apply pressure against the front edge of the plastic light cover and press it toward the back of car. The little plastic clips will allow this to move and you can pull the fixture out easily. Once to have it out, you will see what to do with it.
Hard to know whether this is the visibly suffering wiring for the headlights etc, or if it’s Sam possibly. I guess the fraying wiring is a good place to start looking...
