CL-Class (W215) 2000-2006: CL 500, CL 600
Brakeline corrosion WARNING !!!
Old Apr 19, 2018 | 12:51 PM
pmercury's Avatar
member
CL
Angry Brakeline corrosion WARNING !!!
working on my front brakes applying max pressure
the rear started leaking like HELL !
behind the rubber where it attaches the brake lines for the back, Corrosion on breakline !
+ this is behind the fuel pump cover no way ! I am shocked
could have died !
Please check this all of you
Old Apr 19, 2018 | 01:12 PM
pmercury's Avatar
member
CL
seems to happen not only to me and Benz .....
video deleted
I posted the wrong video here
Old Apr 20, 2018 | 11:36 AM
Geraldius's Avatar
'15 GLK350, '05 CL65 AMG, '04 C320 4matic
Exclamation
The use of compression fittings to repair brake lines, as shown in that video, is an unsafe practice. DO NOT DO THIS!
Brake lines must use correct flare fittings only at connections. Further, if you have corrosion bad enough to cause a leaking line, splicing out one spot is insufficient, as it will just fail again in another spot. Replace the entire line!
Old Apr 20, 2018 | 01:20 PM
pmercury's Avatar
member
CL
this is incorrect information, I have spoken with a specialist and he said that this happens often but only where the line is trapped in rubber guides
using these connectors is professional, the only thing to look for is to use certified fittings and line DIN 74233 + 74234
Old Apr 20, 2018 | 01:30 PM
Geraldius's Avatar
Absolutely not! Compression fitting should never be used in brake lines. Period.They are not designed to work with the pressures possible in brake lines, nor are they designed to work properly with the brake line materials. You will find no authoritative source knowledgable in braking systems that will condone this. There is a good reason the automotive industry universally does not use them.
Old Apr 20, 2018 | 06:10 PM
pmercury's Avatar
member
CL
please talk about things you know of
I confirm again
certified fittings and line DIN 74233 + 74234 are made to repair ALL automotive brake lines
Old Apr 20, 2018 | 06:24 PM
pmercury's Avatar
member
CL
here a demo of a car with OUCH so many dangerous connections.... lol
to repair your brake line, use a female female union piece to connect both sides you see in the video
to remove a larger part I recomment, use two of these and a piece new line
Old Apr 20, 2018 | 06:35 PM
ItalianJoe1's Avatar
2003 CL 600
Happens on all cars when exposed to the elements. Worst case you only lose half your system, could be a problem on a very fast car like a CL, but the pedal will get spongy before it's completely blown. I've replaced rotted lines on all types of cars.
Repair fittings are one thing, but he's absolutely right, COMPRESSION fittings are not the correct type. Flare fittings only, compression fittings can pop off under severe load like panic braking, which would be disastrous.
Old Apr 20, 2018 | 06:59 PM
pmercury's Avatar
member
CL
thx Joe,
I was talking about Flare fittings in my mind
I have these tools
Old Apr 20, 2018 | 07:01 PM
pmercury's Avatar
member
CL
it was my fault actually
I didn't see the first video did a repair with compression crap
I posted that just to show that that kind of line corrosion happens not only to Benz cars and me, I didn't watch the repair
and there is no need to replace the entire lines as very difficult to place sometimes
I always Blackson them all ... but not behind the rubber guides. untill now
Old Apr 20, 2018 | 07:23 PM
2003 CL 600
I see the same issue on metal fuel lines on some cars, they rust through and fail only where they sit in the clips that hold them to the body, so I end up just replacing the section rather than the whole line, if the customer doens't want to throw the money at it to do the whole thing.
I hate doing brake line repairs, I'm very OCD and it's hard to make them look perfect and i don't like them less than perfect.
Old Apr 20, 2018 | 07:31 PM
pmercury's Avatar
member
CL
I do a section because all the lines are in great shape and working on my brakes
and double spal pusher fans since I managed to add another 50HP to my 712
Old Apr 21, 2018 | 06:50 PM
pmercury's Avatar
member
CL
I ended up to rebuild the whole back sections from the fuel pump to the rear wheels
the corrosion is there because no protection panels are there
I repaired a section and twisted the rest a bit and under every place holding the pipe it was rotten and started leaking
If you want to spend a day, go ahead and buy the MB oem steel line, you will have to drop the rear sub frame
If not, do like me and build your own lines
so check the rear lines on your cars !
Old Aug 13, 2018 | 10:56 AM
superangrypenguin's Avatar
A car
Wrong forum. Sorry, my bad.
Old Nov 3, 2018 | 10:57 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
good tip
I've also started having a fuel leak from this same area. I had no idea, but when going for an alignment the tech said "you have a fuel leak". I was in disbelief until he showed me a slight drip of fuel from the fuel pump cover
be sure to check for fuel leaks in this area as well, a few drips isn't a huge deal but people often throw lit cigarettes out on the road behind them... and.. well you can guess the rest of the story
Old Apr 25, 2019 | 07:54 PM
nyca's Avatar
Warning indeed. Just developed this problem on my 2009 W204, 120K miles, otherwise mechanically perfect/well maintained. Dealer wants $6K to fix (car isn't worth $6K) because as above, they say the rear subframe has to be dropped. MB must be using sub quality brake lines on this car - I've had VWs and Fords and Hondas run out to 170K+ miles, never heard of a problem of a brake line corroding/rusting through. Other high mileage W204 owners take note. See the video below, the subframe does not have to be dropped to fix this problem - finding a shop who can do this is a different story.
Old Apr 26, 2019 | 06:08 PM
pmercury's Avatar
member
CL
Originally Posted by ctravis595
good tip
When I got my first W215 I had to replace that whole area
all rusted
anyway, you should replace the filter there every 30000 miles, just a bit easy work
