CL-Class (W215) 2000-2006: CL 500, CL 600
Where should I look
Old Jul 31, 2019 | 12:38 PM
Union City chri's Avatar
2001 cl 500
Where should I look Cl 500 electrical
Recently while driving my cars radio would shut off then reboot itself. It started happening more. Then yesterday first the radio would shut off then the whole car would loose power and shut down. I would pull over and turn the key on and off a couple times and it would power up fine. Then last night I stopped at the store and the car wouldn't start at all. It was as if there was no power at all. After about 15 minutes the power came on and I got almost home when it lost power at a stop light. I sat there for about 5 minutes and it powered on. Driving the rest of the way home, the car radio powered off but the engine stayed running then the radio came back on and made it home. I checked the terminals on the battery and they are tight and fine. Anybody have any ideas where I should concentrate my efforts to fix this? Thank you for any ideas regarding. This issue. Today car started perfectly. Moved the car to my driveway, sat in it a few minutes and it just lost power and died.
Last edited by Union City chri; Jul 31, 2019 at 06:11 PM. Reason: Additional info.
Old Aug 1, 2019 | 08:22 AM
pmercury's Avatar
member
CL
radio shuts off like modules when power goes to low
looks like you have a serious + leak somewhere
best thing is to find a guy with Xentry and let him do a scan
that will probably locate the fault and monitor
Old Aug 7, 2019 | 04:28 PM
2001 cl 500
Found the problem.
Thank you for your advice.
I found the problem. It was in the main fuse module located on the passenger side floor board. There is 3 fuses in that module. 150 amp, 60 amp, and a 200 amp fuse. The 150 amp fuse had heated up. I replaced that fuse and so far so good. Car hasn't shut down nor has the radio powered off. Still not sure what caused the fuse itself to heat up like it did. Thanks again for the reply though.
Old Aug 7, 2019 | 04:37 PM
pmercury's Avatar
member
CL
maybe a water leak on wires
