CL-Class (W215) 2000-2006: CL 500, CL 600
Catalytic converter Help plz
Old Oct 4, 2019 | 02:54 PM
MartinWake's Avatar
CL55
Hey guys I have to get my cats removed on my 2002 cl500 I don’t mind having a check engine light because I will probably code it out in the future anyways I want to remove them because they are causing problems I know there are 4 of them which could I remove that would not give me problems engine wise not check engine light wise or can I remove all of them and the engine Will Be fine? Thanks guys!
Old Oct 5, 2019 | 02:32 AM
MartinWake's Avatar
CL55
Disregard
Old Oct 6, 2019 | 07:56 AM
pmercury's Avatar
member
CL
You can remove everything you want as long as the upstream CO sensors remain in place
should also get rid of those **** mufflers
you can relocate the downstream sensors or leave them in place
you need to code the downstream out
That I did and posted if you search my Threads
