CL-Class (W215) 2000-2006: CL 500, CL 600
🚨 2002 W215 CL500 - Fusebox Location?
Old Apr 7, 2020 | 02:55 PM
BoxxMann's Avatar
02 CL500 | 06 E350 4M
My 02 CL has 3 known fuseblocks. Two under the hood and one under the rear right seat. Is there one on the left side of the dashboard? I took off the cover and there's nothing like a fuseblock there. I want to pull F75, 80 since my Parktronic is on the fritz (someone backed into my rear bumper WTF!). Any help?
NB: If there is a link for the fuse layouts, it needs to be pinned.
Old Apr 8, 2020 | 10:11 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
I know for certain that a 2001 CL only has the 3 above mentioned fuseboxes. I don't know about 2002. This question has come up previously, cannot remember what the final answer was.
Old Apr 9, 2020 | 07:41 PM
BoxxMann's Avatar
Tx Yes, I can only locate 3 on my 02. Fortunately, I pulled #75 located on the rear seat block and that disabled Parktronic.
Old Apr 10, 2020 | 01:43 PM
pmercury's Avatar
member
CL
Lucky if you don't get any warning lights
Usually you should disable devices properly with Xentry and remove it from the connected modules like central gateway
Old Apr 10, 2020 | 06:03 PM
BoxxMann's Avatar
It's parktronic - it's on its own circuit. No lights. And the fix is free
Old Apr 11, 2020 | 12:58 PM
calgary's Avatar
Question: How difficult did you find it to work on the fuse box under the back seat ? I have real problems getting to the different fuses.....Did you have to cut some of the carpeting ?
Old Apr 11, 2020 | 10:08 PM
BoxxMann's Avatar
one of these:
https://www.ebay.com/itm/Universal-A...EAAOSwtKtZ4RAp
the fuse diagram and a flashlight
Old May 30, 2020 | 02:05 PM
pawraw's Avatar
CL 55 AMG
On a left hand drive car the fusebox is on the right side on a righthand drive car it's on the left side. No carpet cutting is needed to access the fusebox under the back seat - there is a removable cover
