CL-Class (W215) 2000-2006: CL 500, CL 600
Battery warning... :(
Old Oct 24, 2020 | 03:12 AM
MartinWake's Avatar
CL55
Hello guys, I was driving back home and as I roll my windows up I notice they are extremely slow, so I plug in my bluetooth obd scanner and use the torque pro app to see the voltage I see its reading 10.4-10.3 which is pretty low anyways after a bit it went down to 9.8 and I got the warning on the dash.
I turned my lights and ac off to try and save power. The car got home but as soon as I turned it off it did not turn on, I hooked up a battery charger and after a couple mins started back up.
I think it could be the alternator but I have been reading about a part in the passenger foot well that could also cause this to happen?
My friend had a similar problem on his cl500, he changed the alternator and still acted up. He says its the starter but that does not make any sense.
If anyone could help me out plz thanks.
Old Oct 24, 2020 | 09:39 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
It's my guess that nearly all alternator replacements are entirely unnecessary and in each case the voltage regulator was the problem.
The alternator charges the battery through a 150-amp fuse located in the passenger footwell (picture). I'd check that fuse.
Old Oct 24, 2020 | 01:06 PM
MartinWake's Avatar
CL55
yes that's the one I was referring to in my post, gonna check that.
Old Oct 24, 2020 | 09:51 PM
MartinWake's Avatar
CL55
Checked all those fuses visually and with a multi meter, They are good. I charged the battery and went for a drive saw 13.6 then down to 11.9, once I stopped opened hood and smelled burnt rubber right on top of alternator... I think we found the problem.
