CL-Class (W215) 2000-2006: CL 500, CL 600
Rear window wont shut (close gap)
Old Nov 15, 2020 | 05:46 PM
MartinWake's Avatar
CL55
I had my battery disconnected for a few days and usally the windows dont shut so I roll them down and back up and that fixes it but now the rear window shuts when I click the button but not when the door closes?? any idea what I can do to fix this?
Thanks!
Old Nov 15, 2020 | 10:37 PM
MartinWake's Avatar
CL55
fixed
Old Nov 16, 2020 | 11:29 AM
biker349's Avatar
cl600
what did you do to fix it.
Old Nov 16, 2020 | 01:57 PM
MartinWake's Avatar
CL55
put window down hold it for a bit and back up and hold it for a bit but I think the problem happened when I opened the door before connecting the battery so it confused the car now if I connect battery first then open the door it works fine..
Old Nov 16, 2020 | 04:32 PM
BenzNinja's Avatar
Former Vendor
thats called a reset
same for the roof
but you open it wide as possible to max, then hold 4 sec
then close and hold it runs fully closed + up and hold 4 sec
every time you remove the battery this must be done
