CL-Class (W215) 2000-2006: CL 500, CL 600
Engine M137 plug at the rear of the engine block.
Old Nov 29, 2020 | 07:59 AM
M137's Avatar
CL600 215 M137
Question Engine M137 plug at the rear of the engine block.
Hello all,
I wanted to connect the oil pressure sensor on the M137 engine.
There is space in the oil filter housing.
But I found a plug on the back of the engine block.
Do you know what this plug closes ?
Could it be an oil channel ?
I will be grateful for your help.
Old Jul 18, 2022 | 02:51 AM
tim687's Avatar
CL 600 '00 5.8L V12
Did you end up knowing what this plug was for?
Old Sep 8, 2022 | 01:53 AM
tim687's Avatar
CL 600 '00 5.8L V12
The oil pressure gauge should be connected to the plug under the oil filter housing.
