Head Scratcher - 2002 CL600
another thing is maybe accelerator pedal module is failing, common failure on w215’s
It might just trigger the codes to come back
If you write these settings through developer mode, don't forget to turn the ignition off for 10 seconds before trying anything else.
When you're doing tests you're probably sitting stationary rather than checking it at the time there is going to be a problem.
If the fuel pump is only delivering 70% of what it should you won't be able to drive the car but it'll start and idle okay and test fine. It's just when you're demanding greater volume it can't deliver.
SOME diagnostics systems will give you pump RPM. I dunno if that's available in this case. If it is then you should verify the pump RPM is correct.
