CL-Class (W215) 2000-2006: CL 500, CL 600
2004 CL Trunk lifting halfway FIXED
Old Dec 2, 2020 | 06:46 PM
ukcl600's Avatar
C215 600TT
Post 2004 CL Trunk lifting halfway FIXED
As the title suggests... Like many folks that scour the internet at night reading the same procedures in a half-willed battle to fix that pesky half opening boot lid, all my attempts (also) seemed futile. Convinced it wasn't a hydraulic issue, I set about trying all the options I could find without getting my hands dirty.
I too, don't have that mysterious menu on the dash.
The holding a button for 5 seconds also... nearly took my hands off.
The trigger on the door panel. Nothing.
I even read the w220 wiki trunk page Trunk - W220 S-Class Encyclopedia - from top to bottom. At least I now know how to break into my own car.
Then it hit me. If you are going to re-teach the car where the boot lid is, don't keep telling it that 'fully open' is at the halfway mark... I know, I know... Seems simple now right? Why did nobody mention this!
Assuming you have checked that you definitely DO NOT have the trunk lid limiter option...
You don't need to run the engine, you don't even need the key in the ignition. I would suggest somewhere dead quiet though... Read on.
1. Open the boot however you like. It will stop halfway.
2. Slowly push the boot to the fully open position.
3. Open the driver door.
4. PULL the boot release button so that it clicks and hold it for 10-15 seconds.
4a. If you listen closely, you will hear something mechanical in the trunk area do a little dance and stop.
5. Close the boot however you like
6. PUSH the boot release button so that it clicks and hold again for 10-15 seconds
6a. You will hear that little dance again.
7. Open the boot. You're welcome.
Old Apr 12, 2022 | 01:06 AM
thesheikh's Avatar
97 SL600, 03 CLK55, 03 S55, 04 SL55, 05 C55, 07 R500
Tried this 3 times on my w211. Unfortunately did not work. 🙁
Old Apr 12, 2022 | 01:49 AM
tim687's Avatar
CL 600 '00 5.8L V12
This is easy to read over, could you explain what it does and how people should know it's there?
Old Apr 12, 2022 | 02:15 AM
thesheikh's Avatar
an on/off option in the settings on the cluster that you control with the steering wheel. I believe it is settings > vehicle > trunk limiter on/off
Old Feb 6, 2025 | 11:16 AM
bneinast's Avatar
2002 CL500, 2003 SL55
Awesome! It worked. Almost gave up til I did the second part of the program. Pushing the door button down for 10 seconds when the trunk is closed to complete the program did it. Thanks!
Old Feb 8, 2025 | 02:05 PM
Fried Chicken's Avatar
2005 S500 Designo
It warms my heart when people post solutions, and it's so underappreciated. Well done.
