CL-Class (W215) 2000-2006: CL 500, CL 600
Battery trunk support plate and plugs in the main wiring, CL 500 2002
Old Jan 31, 2021 | 09:29 PM
reise's Avatar
Mercedes-Benz CL 500 2002 Brilliant Silver Metallic
Hi everyone. If I don't use the CL 500 for a few days, I find it with a flat battery. After buying the car on January 19th, I took a 500km trip to take it home.
I only restarted it the next day (20).
So it was closed for 7 days without using it (I haven't had time for a nice detailing yet, so it is currently still dirty (sacrilege)).
On the 27th I try to start it (it was necessary to move it) and it does not turn on. I connect the cables to the battery for a jump start and it goes straight away. So the battery was just dead.
I try again on the 30th to restart it (I had to move it again) and it does not start again.
This time it doesn't even start with the jump start. Indeed, after a few attempts, the instrumentation stops working. I look at the battery and I notice that acid has leaked from a couple of elements. Then I disconnect the jump start cables and remove the battery from the car.
Here is the battery:
I find some surprises. Under the battery there is no support / plate, but a deep vacuum.
Here's what I'm talking about:
Furthermore, a plug of dubious functionality is connected to the positive pole cable.
I refer to this graft:
A plug is also connected to the negative pole cable, but this can be connected to the 12V socket.
The cable initially was disconnected:
So I tried to plug it in myself and found that it actually plugs into the 12V socket:
Is the 12V socket in the trunk false, or is it originally intended?
Here you can see it the additional cable plugged at negative cord and the 12V plug:
However there is a fixing bracket (but the bolt is missing):
Ultimately I would like to understand if I need a support plate for the battery and if the connections to the cables and the 12V plug are original or a non original aftermarket install.
Sorry for the pictures with the CL and its dirty accessories, but after buying it I still haven't had time to detail.
Old Feb 1, 2021 | 04:11 PM
BenzNinja's Avatar
Former Vendor
this is what fits under the battery, cover with trunk pump
Old Feb 1, 2021 | 04:26 PM
reise's Avatar
My CL has no electro-hydraulic trunk lid, so I don't have the pump. But is it normal that there is no cover under the battery? While the 12V socket is aftermarket? And the connector on the positive pole?
Old Feb 1, 2021 | 04:50 PM
BenzNinja's Avatar
Former Vendor
I don't know if normal but not needed
no idea about the socket
if you send me the vin I can lookup in EPC
Old Feb 1, 2021 | 06:31 PM
reise's Avatar
VIN: WDB2153751A030208
