Can running ABC pump dry damage the PS side?
With that out of the way, I am planning on fitting either YellowSpeed or Ceika coilovers (currently working through the minefield of which is best out of the two and which spring rate is best!!) but until I get those, I am trying to understand what is the worst that will happen if I drive the car with no ABC fluid? I can't even keep it topped up as it will leak 2 litres in 1 short journey so it ends up costing more in oil than fuel! I know the pump will be destroyed, but it is already, I am more curious as to whether the shocks stay up or will they end up hitting the floor?
And further to this, I read a few reports online that once you replace the shocks you can just leave the ABC pump in place, with no oil, and there is no damage to the PS side. Is there truth in that?
