CL-Class (W215) 2000-2006: CL 500, CL 600
ABC drive carefully after valve block rebuild
Old Jun 20, 2022 | 05:08 AM
D.militaria's Avatar
Cl500 w215 R320 w251
Hello, i have recently rebuilded the rear valve block and installed lowering links. After puting all together and toping up the oil, after turning on the car i have a red warning abc drive carefully. Any tips what should i do? Do i have to pressurise the system somehow? Thanks
edit: i've found a thread whit simillar problem, do you have any tips how to do it step by step, without damaging the tank?
Old Jun 20, 2022 | 07:29 AM
tim687's Avatar
CL 600 '00 5.8L V12
Where did you came from?
Was the oil resevoir empty?
Did it sag?
Is it currently sagging?
Try to read the fault codes out with SDS/DAS and go from there. It is impossible to diagnose these cars without SDS/DAS
Old Jun 21, 2022 | 04:40 AM
Problem solved
Old Jun 21, 2022 | 05:41 AM
tim687's Avatar
CL 600 '00 5.8L V12
What was the issue/solution?
