CL-Class (W215) 2000-2006: CL 500, CL 600
Driveshaft U-Joint Part Number?
Old Jul 5, 2022 | 06:53 PM
Viper GTS's Avatar
2000 CL 500
Question Driveshaft U-Joint Part Number?
Does anyone know the part number for the Universal Joint in the driveshaft by chance?
2000 CL500
Getting one just by size may be tricky.
Size: cap diameter : 0.945" , length = 3.5"
Thank-you.
Old Jul 19, 2022 | 09:32 PM
Viper GTS's Avatar
2000 CL 500
I did get one and replaced it. Its a metric size. If you search for a "24mm x 88mm Staked U-Joint" you will find some online. Mine is a perfect match.
If you replace yours be sure to completely remove (grind out) the old staked points in the yokes. If there's even a little bit left they can crimp the new caps upon install shrinking it and ruining the cap.
Old Jul 20, 2022 | 07:13 AM
tim687's Avatar
CL 600 '00 5.8L V12
Please bookmark: https://nemigaparts.com/cat_spares/e...fg/215378/68r/
It will allow you to find all the parts of the CL. You might want to select the CL500 first ;-)
Old Jul 20, 2022 | 06:50 PM
Viper GTS's Avatar
2000 CL 500
It doesn't have a part number in there. They want you to buy a whole new shaft.
Old Jul 21, 2022 | 02:07 AM
tim687's Avatar
CL 600 '00 5.8L V12
I can imagine why, the shaft has been balanced as a whole. So you'll need both ends of the shaft to keep that balance.
That's why you can't and shouldn't replace the U-joint and or one of the shafts
