CL-Class (W215) 2000-2006: CL 500, CL 600
Cl500 tcu
Old Sep 13, 2023 | 12:04 AM
05cl500's Avatar
2005 Cl500
Cl500 tcu
I have a 2005 cl500 with the 7 speed and I can’t find the Tcu/tcm anywhere has anyone located there’s or is it inside of the transmission like the later years?
Old Sep 13, 2023 | 12:28 PM
Nemanja34's Avatar
1980 Mercedes 450SL, 2005 Mercedes e320 CDI, 2014 Mercedes e63s
The 7 speed may be different, but I know the five speed is in the fusebox in the top passenger side of the engine bay. It's really easy to pull out and swap, no programming is necessary for the 5 speed, unsure about the 7 speed.
It is the N15/3
Old Sep 15, 2023 | 11:23 AM
darbysan's Avatar
cl500
I'm pretty sure the 7 speed is inside the transmission. Have to drop the pan, then remove the Valve body. I believe that if you replace this part, it needs to be carefully mapped via Xentry . You may also need to copy current specs from your TCU via Zentry before replacement. If you go this far, be sure to check / consider replacing the speed sensors, as they are a known failure point.
You might contact Module Repair Pro, 5911 Lemona Ave, Van Nuys, CA 91411. THey did the repair for my sped sensors, as well as the ABC controller repair. I believe they are familiar with the TCU's as well. 1-818-235-1095
