Opinions on a CL600
Im looking an ‘01 CL600 with 94,000 miles. I did a lot of research to prepare myself and here’s what I found/observed:
ABC: Surprisingly works. What I did notice is the front struts have uncovered coil springs. I did come across a few pics with visible coils but most seem to have a cover. Does this mean anything? Were they replaced or serviced?
Dash lights: Lots of codes, front pads, check engine, lots of bulb light codes.
Brakes: Work ok but the pedal is long and somewhat spongy. Front rotors are whipped so it’ll need pads and rotors.
Temp: it was 92 with a feels like of 99 and it was doing ok. Electric fan was working.
Engine: Definitly down on power, probably needs a good tuneup with plugs at a minimum. No smoke.
Electrics: Drivers door switches do not work. I couldn’t adjust the seat or lower the windows or any of that. This is most concerning to me as I couldn’t find any switches online anywhere.
Exhaust: Intact
Rust: None. Underside is clean.
Randon stuff: There are a few wires that clearly were rigged up, some kind of ground and another wire going out the grill, this one looked like a temp sensor.
Front underbody air dam: When the hoods open you can see the ground. Is there supposed to some type of splash shield underneath?
Any thoughts or comments?
Pics of cobbled ground at the front bottom of the passenger valve cover. And an area of ‘wetness’ at the back of the engine, drivers side. And then a few randoms…
I love this kind of question, let me pour all of my knowledge of my 2000 CL600 into my answer
Oh and for the temperature, it'll fluctuate between 84 and 97 degrees depending on the air speed, thus the cooling efficiency.
Disconnect the battery though, since there is an airbag wire in that harness.
100 and 110 are for cooling the engine mounts. Yeah it's ridiculous, I know. Don't skip out on them or the engine mounts will skip out on you.
As for the wetness at the back of the engine, the oil cooler heat exchanger is a common weak spot on these engines. When the gasket in between fails, the heat exchanger needs to be replaced, which requires both heads to come off.
You could use rubber seal restore, made for use in engines to soften and expand the rubber gasket a little. It might allow you to get a few more miles out of the current exchanger.
I'd start thinking about replacing all ABC hydraulic hoses with custom made ones, when they fail you need to stop the car immediately, otherwise you'd destroy the pump.
[/QUOTE]
Covers are missing on the engine itself.
490 and 500 are missing.
In general, a good clean of the engine bay and a few small things will make it nicer very quick.
I'd replace all oil, filters (including transmission and diff oil), sparkplugs and O2 sensors preventively and then do an italian tune-up.
Also, perform maintenance on ABC. Flush the system, change the filter and continue to check fluid level whenever you've driven it to see if it's leaking somewhere.
A few more questions:
Strut covers: Are they available or is there a work around?
Coil packs: If they need replacing, are the 'rebuilt' holding up okay?
Brake pads: Low dust is a must!!
Schematics: Where did you get the pics? Are there any 'must have' manuals or repair guides?
The price is right on the car, I'm guessing anywhere from $500-$3000 to get it fixed. Does that seem reasonable?
It is a very satisfying car to work on as the rewards are great. I've learned wrenching on this car and about half a year ago I replaced bot camshafts + roller assemblies because they where worn due to rust.
These are one of the only parts you can actually safely get from China: https://s.click.aliexpress.com/e/_DBYWaMB
For quite some time I've been running a DIY repaired voltage transformer and Clarks coil pack. It's only until recently I started to doubt the coil pack. Mercedes also provides coil packs, similairly priced to Clarks
I don't have one available whilst I am at work, so I regularly use this one Mercedes FG 215.378 (68R) > Mercedes EPC Online > nemigaparts.com
Bookmark it
However, some of the part numbers are VIN specific and nemigaparts will not show everything correctly, so for some part numbers, you'll need EPC.
If there isn't any fluid in the ABC reservoir when you come to look at it, don't buy it
Next to the must do's in my first post; here is another one
The ABC system features 2 accumulators, if they haven't been replaced recently, replace those. It could cause a burst of nitrogen in the system, spitting out all fluid from the reservoir.
There are several additives one could add to the fluid to re-expand the rubber o-rings inside of the system.
The fluid does need to be meticulously clean before you do that however.
In conclusion, I partially agree with you. ABC is a risk, but then again, with proper maintenance I've seen cars go 450k km's with ABC.
I’m going to take a second look and pay particular attention for the infamous oil leak. If the leak is minimal I’m going to throw a low ball offer of $5k.
