CL-Class (W215) 2000-2006: CL 500, CL 600
ABC on 2001 CL600 (help)
Old Mar 8, 2025 | 03:58 PM
ahusan215's Avatar
The car is completely grounded. I am stumped on to what it could be. I speculate it could be the Tandem/ABC pump but not 100%.
Old Mar 9, 2025 | 03:36 PM
ejenner's Avatar
CL500, W212 e350 mega-spec
When you say 'grounded' do you mean it has dropped on all four struts so is on the ground or do you simply mean it can't be driven due to suspension problems...
Have you got a diagnostics tool of any sort? If not then good idea to get one if you have any old Mercedes as they love to invent new faults on a weekly basis sometimes.
It's about £120 for the Foxwell tool which does pretty much everything. You have to buy it with the Mercedes codes already loaded and then if you get a different car later you can add new packages to cover other makes.
If the pump has an issue then the system pressure will say zero in the diagnostics info. i.e. no pressure because the pump isn't running.
Dare I say it, it's not an especially complicated system once you're aware of all the components, where they are and what they do.
You need to provide more info about your issue to have any chance of any more detailed help.
Old May 8, 2025 | 10:16 AM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
If there is an external leak, its probably one of the hoses that burst. If nothing is leaking externally its probably an internal leak from one of the valve bodies or the pump is not pumping.
There are two valve bodies, one in the back, which is easy to find, and one in the front left. Have to take the panels around the wheel off to get to it.
