CL-Class (W215) 2000-2006: CL 500, CL 600
cl600 tail light removal?
Old Jan 30, 2005 | 08:20 PM
str8spd2001's Avatar
Hey Guys-
I have an '01 CL600 and was wondering if anyone can please help me with instructions how to remove the rear tail lights. I tried doing a search but came up with nothing. Maybe I'm just wording it wrong. Thanx for any help.
Old Jan 30, 2005 | 08:50 PM
awiner's Avatar
2003 CL55 AMG
Open access the inner tail light assembly like you would do if you needed to change a bulb.
Unclip the large black electrical connector (2).
Unscrew Nuts (3).
Carefully open flap (1) and unscrew nut (3a)
You will find 3 nuts you need to unscrew.
Remove tail lamp. Be careful not to damage gasket. If you do, you will need to replace the gasket. Make sure upon re-install the gasket is seated correctly.
Old Jan 31, 2005 | 01:52 AM
Thanx AWINER. The picture and everything helped a bunch.
