CL-Class (W216) 2007-Present: CL 500, CL 600
First problems on '07 CL
Old Jan 15, 2007 | 07:11 PM
Psycho's Avatar
Picked up a launch edition '07 CL a month ago, and I have wind noise on the driver's side. It sounds like it's coming from the door jam. Dealer tried adjusting the soft-close feature so it pulls the door tighter, but the problem is still there. The door brake on that side is also squeaking, causing a creak whenever I open or close that door. Dealer has ordered a new brake, so we'll see what happens. Anyone else had these problems?
Old Jan 17, 2007 | 03:26 PM
Soon2bMB's Avatar
2008 C300W4 Sport, 2006 Honda CBR600F4i
havent had any problems, here but i will make sure i keep an eye out for problems on the 07 CL
Old Jan 17, 2007 | 03:31 PM
amgme's Avatar
07 SL550; C32 (sold)
first year model = bugs.
could it be the seal around the door?
Old Jan 17, 2007 | 03:55 PM
pmb600's Avatar
E550 4MATIC
What about the window, on Mercedes coupes when you close the door the window goes up about half an inch to make a tigher seal. Is it not sealing properly?
Old Jan 17, 2007 | 11:15 PM
SL65amg's Avatar
'05 SL 55 Black/Black w/mods from Eurocharged/Kleemann/BuckheadImports
Thumbs up I haven't had any problems yet on my LE CL 550
I haven't had any problems yet on my LE CL 550, and hopefully I won't. I'll keep an eye out for stuff though.
Old Jan 19, 2007 | 08:55 PM
02S430's Avatar
W220 M113K
thats true, i agree
Old Jan 22, 2007 | 02:04 PM
sooners's Avatar
cl500-o5, s500 sedan-o4, new s550 sedan
wind noise is always a problem in my 05 cl, for some reason when it is really windy outside and i am going 55+ it seems nosier than on a non windy day and i am traveling at the same speed.If the windows are sealing properly you should hear a audible thump\ thump, side seal, and then up.good luck.
Old Mar 19, 2014 | 11:27 PM
DigitalmikeCL65's Avatar
CL65 AMG
Hi I just want to check did you found the what was the problem with the wind noise? I have an 08 and same problem. I can hear the wind and street noise from drivers side door. Like its coming from where the window meets the door. It drives me crazy.
Old Mar 20, 2014 | 08:57 AM
Psycho's Avatar
The problem was eventually fixed. The dealer said there was a bulletin to address this. I don't own that car anymore, and unfortunately I don't know the number of the bulletin.
Old Mar 27, 2014 | 08:49 PM
Larengineer's Avatar
CL63 AMG
The window module controls the window position height and it can loss its memory. Try reflash/program. Dealer want to replace everything.
