CL-Class (W216) 2007-Present: CL 500, CL 600
Upsizing wheels
Old Feb 15, 2008 | 10:50 AM
mbpark's Avatar
Bentley GT, F360M
Upsizing wheels
My CL500 is currently on stock 255/45 8.5j R18s. Non staggered.
Can anyone advice me on what the current offest is (ET)?
Is it 43 or 34?
I am looking for a non staggered set up for 20inch wheels so i guess 255 is the max?
Can the car take 22 inch wheels, any rubbing?
Any advice is much appreciated
Old Feb 17, 2008 | 09:08 AM
ColdWater's Avatar
CL600, G500, E-type, Alfa SS
Suggest that you refer to pages 75-76 of the AMG accessories brochure at http://www.mercedes-amg.com/assets/p...ccessories.pdf
This indicates ET 43 for all wheels offered, and recommends 255 for 8.5 front wheels. In the rear they allow 275 on 9.5.
IMHO 22s look comical and cartoonish on a W216 CL, but judge for yourself: https://mbworld.org/forums/cl55-amg-cl65-amg-cl63-amg-c215-c216/220744-new-pics-shoes-calipers-tint-lowering.html
The AMG Style IV 20s used on the CL65 and CL63 030 package are IMO some of the best looking wheels anywhere and particularly well suited to the W216. I'm putting these on my CL600 which arrives at the dock next week. Some board members have disparaged letting the world see one's smaller non-AMG brakes through more open wheels, but I figure that if it bothers me I'll just go to RENNtech.
Would appreciate hearing from other board members:
1) tire recommendations - I'm thinking PZeros, as wet weather performance is important to me;
2) if anyone is interested in buying the unused stock take-offs from my CL600.
Old Jul 11, 2008 | 12:47 AM
pocket's Avatar
2000 cl500
big wheels
I have a 2000 cl500 sitting on 20in tsw 5 spoke with 8.5 245/40/20 front and 10in 295/30/20 back. The back are really wide and look meaty but I get slight rub when hitting bump or dip under hard cornering. But for the most no problem. After this set of tires wear out I will go to 275/30/20 on the back and that should cure it. Mean while the patch these tires lay is impressive.
Old Jul 11, 2008 | 03:22 AM
ohlord's Avatar
You
need to rethink your tire size choice.The tires you have are smaller in the rear than the front and spin 21more revs per mile,going to a 275 will make it worse at 35 more revs per mile.Might even play havoc with the abs,asp and cruise control.
245/35/20 front and 285/30/20 are within 1 rev per mile and with proper offset will clear all metal work.
always a good idea to check plus size rims and tire combos
both of the above tire choices come within 1/100 of an inch of the oem diameter tire.
at present your front tire is almost 3/4 of an inch taller than the rear.
OP 22's will look as ricey as it soundsand ride like one also.
Old Jul 13, 2008 | 05:14 PM
germankars's Avatar
Porsche ,MB, others
with 19" AMG rims you should have 8.5 245 or 255 35 in front
and 9.5 275 or 285 30's in rear
with a 20, the proper aspect size is really a 30 in front, and a 25 in rear..
that said if you do go with 20's you can get away with the 30's in the rear,
but it will make your speedo, and electronics slightly off
but its a more confortable ride...and the tire fills the wheel well more
Old Jul 21, 2008 | 12:15 AM
Alex@wheelexperts's Avatar
07 S550 & 08 335i
I would go for the 20" Option over the 19" option...
Here is a CL55 we did a while ago. It is on 20x9 and 20x10 Zone 1 wheels. For tires, it has 245/35/20 and 275/30/20.
Please feel free to PM me if you have any questions, or if you would like any information regarding any products...
