CL-Class (W216) 2007-Present: CL 500, CL 600
Lowering W-216 w/out module???
Old May 24, 2010 | 06:34 PM
speedyralph's Avatar
Can somebody point me to the right thread on how to lower a 2008 CL550??
Thanks!
Old May 25, 2010 | 08:46 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Links... washers... or Find someone with as star diag
Old May 25, 2010 | 09:03 PM
Red Marko's Avatar
Protecting the Earth from the Scum of the Universe
Simple.
Drive with your Mother-in-Law.
Old May 26, 2010 | 01:21 AM
John V.'s Avatar
Former Vendor of MBWorld
2007 CLK63 Cab
I can help!!!
Old Nov 21, 2011 | 12:45 AM
adamls2's Avatar
W215 CL65
Originally Posted by Red Marko
Simple.
LOLOLOLOL
Old Nov 22, 2011 | 01:23 PM
untamedd's Avatar
2019 AMG GT R
Originally Posted by John V.
I can help!!!
I wanted to ask you if one can easily go back to stock height with your links? Also, will the inclination angles affect my alignment whatsoever? Thanks
Old Nov 23, 2011 | 07:28 PM
adamls2's Avatar
W215 CL65
I found some links on eBay that are adjustable so I guess you can go back to what ever height you desire. I'm not sure if they are all like that though. As for the alignment, when ever you lower the car you will definitely change up the camber specs which would require alignment after lowering. I think if it's more than a one inch drop it won't be able to align the car into the "green area" but I'm not really sure with this car. I'm also still trying to search around for answers myself.
Old Nov 23, 2011 | 07:33 PM
untamedd's Avatar
2019 AMG GT R
The solution to that I guess is to get the car lowered at any alignment shop since they'll have a Romess inclinometer which can set everything straight.
Old Nov 23, 2011 | 08:36 PM
adamls2's Avatar
W215 CL65
That sounds good. I wonder how they would charge for it though? And how does that actually hook up and work?
Old Jan 17, 2012 | 09:12 PM
Merc63AMG's Avatar
2009 CL63
I have had nightmare after nightmare, First was the renntech V3 module, for some reason i could never get that right. always threw codes when it was lowered. same thing with the links. they are so hard to set exactly right. The car is so advanced it throuws codes that say what suspension is not level. Then if you try to get an aggressive look for say parking or driving in a straight line the car will try and adjust itself and make itself lever. feels like someone is banging on the car. I havent checked into any other options. let me know if anyone has a solution. thanks
Old Jan 17, 2012 | 09:56 PM
JMKSAIL's Avatar
SL500 CL600 Carlsson
My Carlsson package came with the Carlsson engineered lowering module, push a button goes up high, push again goes low, drive fast, goes lower, bumpy road, raises automatically. does not change suspension feel.
Love it. Mercedes approved and warrantied.
