CL-Class (W216) 2007-Present: CL 500, CL 600
CL 500 Dead Battery I can Help
Old Apr 9, 2014 | 10:02 PM
ciggie's Avatar
2002 CL500
Ok all this is what you can do to open the trunk. It's fast and easy. Pop the hood. Drivers side fuse box, remove cover. You should see a big 50 amp fuse. Beside it is a smaller 40 amp red fuse. Take a booster pack, a small slot screw driver. Clamp power cable to screw driver and black to ground bolt on shock tower. Touch the right side of the fuse with the screw drive and hit the trunk release button on your remote. It should pop your trunk... good luck all....
Ciggie.
