Vibration
Vibration through seats at 60mph and over. Vibration can also be felt through steering wheel but less so. ive changed track rod ends and cant feel any play in any of the arms. i believe front arm bushes are "common"? If so, lower front or lower front rear?
Finally, If car is stood for a couple of days, on driving the vibration is worse until it is warm then it reverts to normal. I may end up replacing alloys and front arms but could do with a little help from the experts on here.
Thanks for any assistance you can give.
To rule out drivetrain, shift the car manually down a gear or two, this will increase engine and transmission input speeds. If there's no change in the vibration, it has to be something further down.
Normally, felt in the seat vibrations are from the rear axle or driveshaft, not the front end. I'd have the center support bearing of the driveshaft inspected as well.
But balance the tires first.
Great support from forum. Thanks.
