CL-Class (W216) 2007-Present: CL 500, CL 600
Comand unit Memory card option
Old Apr 24, 2018 | 08:29 AM
madlyhs's Avatar
CL 500
I bought PCMCIA adapter for my 2009 W216 & i downloaded some music to a memory card and inserted it in the PCMCIA slot in the Command unit . However, From the Menu I selected Audio but sadly I don't see Memory card option under the Audio menu to play the music on memory card !
Under the Audio menu i can see Radio , CD, DVD, Mp3, Aux but no memory card option!
Do i need to have the option activated on the command unit ?
Old Apr 26, 2018 | 09:43 AM
xabo's Avatar
'20 S63
Select Mp3.................................
Old Apr 26, 2018 | 09:08 PM
madlyhs's Avatar
CL 500
If I choose mp3 the CD will play instead of the memory card , and if i remove the CD and select mp3 again.. it will search for a CD ....Strange
Old Apr 26, 2018 | 09:13 PM
xabo's Avatar
'20 S63
Do you have a pic of your adapter?
Old Apr 27, 2018 | 03:13 AM
madlyhs's Avatar
CL 500
I got it from Ebay as per the description its PCMCIA TO SD SDHC CARD Adapter Converter up to 32GB for Mercedes-Benz Media
Thanks for your help
Old Apr 28, 2018 | 10:38 AM
xabo's Avatar
'20 S63
Have you tried using a regular SD card? You can search PCMCIA in the W221 forum as there's been a lot of discussion on this topic.
Old Apr 28, 2018 | 12:40 PM
xabo's Avatar
'20 S63
This is the setup I'm using
Old Apr 29, 2018 | 06:24 AM
madlyhs's Avatar
CL 500
I did not use a regular SD card yet i but i did get another adapter but not luck still same problem .
I did search the forum for all topic related to PCMCIA adapters and which memory card to use i thought mine will work but didn't .
I'm trying to determine if the issue is adapter/ memory card or my command unit ?
By the way are you able to see the Memory card option under the audio menu even if the adapter/memory card is removed from comand unit ?
I'm wondering why I dont have memory card option under the drop down Audio menu in my car ! Is it an option that needs to be activated before I'm able to use it ?
Old Apr 30, 2018 | 06:23 PM
xabo's Avatar
'20 S63
I have no memory card option. I use the MP3 option. I was never able to get the SD cards to work that's why I went with the Compact Flash.
Old May 1, 2018 | 09:19 AM
madlyhs's Avatar
CL 500
I just ordered same setup as yours hopefully it will work
Thank you for all your help and support.
Cheers
Old May 10, 2018 | 06:52 PM
xabo's Avatar
'20 S63
Any updates?
Old May 11, 2018 | 02:24 AM
madlyhs's Avatar
CL 500
Sadly no luck still did not work
I paid a visit to Mercedes dealer to get advice , and was told i need to leave the car with them to check. They said if command unit faulty they might not be able to fix it and i need to buy a new Command unit .
The cost will be around $10,000 ($10K) OMG !
Not sure if its the adapter or the command unit might consider buying a used unit .... Is it plug and play or does it still require programming to work in my car ?
Old May 11, 2018 | 02:34 AM
madlyhs's Avatar
CL 500
I did format using Fat and Fat 32 both did not work
Old May 11, 2018 | 10:39 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
I have tried various adapters/memory card combos and had no issues. The only thing that gave me an issue was if I created folders and put the music in there. If the MP3s were in the root of the memory card everything worked fine.
Old May 12, 2018 | 03:10 AM
madlyhs's Avatar
CL 500
i just put all the songs in the root directory without any folders and i still have the same problem
I'm clueless
Old May 29, 2018 | 03:07 AM
madlyhs's Avatar
CL 500
Since my last post i gave up on the SD card but today i decided to try one more time so i ejected and reinserted the SD card and to my surprise it worked ..... not sure how and why but its working now
Thank you guys for your help and support
Old May 29, 2018 | 10:06 AM
xabo's Avatar
'20 S63
Glad it worked out for you...................I forgot to mention there's a slight lag before the music starts playing.
Old May 29, 2018 | 11:49 PM
madlyhs's Avatar
CL 500
Aha now i know why its working now.....
Old Sep 9, 2018 | 05:45 AM
Peacheyd's Avatar
2007 CL500 5.5 W216
has anyone managed to use a greater that 32GB micro SD in theirs? at the moment im using a 32GB Micro SD in an SD adapter, i bought a 128GB card to replace it with but the car wouldn't read it and i wasn't sure if it was my PCMIA adapter or a limitation in the cars software.
Old Sep 12, 2018 | 08:48 AM
madlyhs's Avatar
CL 500
I
I have Cl500 2009 I'm using 128GB memory card and works fine .
Old Sep 12, 2018 | 10:09 AM
megacrazy's Avatar
Interesting. That's good to know. I assumed it wouldn't go over 32GB and never tried a larger card.
Old Sep 12, 2018 | 10:25 AM
madlyhs's Avatar
CL 500
Me too I assumed the same but after testing it works fine... There is few minutes delay before start playing depending on how many music GB's you have on the memory card.
Good luck
Old Sep 12, 2018 | 02:02 PM
Peacheyd's Avatar
2007 CL500 5.5 W216
I wonder why mine won't work then. What PCMIA adapter are you using?
Old Sep 13, 2018 | 02:34 AM
madlyhs's Avatar
CL 500
This is the one i'm using now ... My car from Kuwait so maybe different spec or firmware.
I'm not sure why its working cos I assumed 32 GB was the max you can use. I have less than 2 GB songs on my memory card.
