No Bluetooth audio option
Hello All, need help with enabling 2013 CL 550 - bluetooth audio option. Cell phone is connected through bluetooth but there isn't an audio option. Read there might be way to enable through engineering mode but don't know how to access it. Any help is appreciated. Hard to believe this car didn't come with bluetooth audio!
2002 Mercedes Benz SL500
Check your glove box. If you have a weird connector in there, then this is what you need. You will also need to turn on "Auxiliary" input on in your Comand. This thing works great. I installed one in my '07 CL600 in 2018 and it just flat works!
Have fun!
Have fun!
There is a device you can buy that will give you Bluetooth audio but I am not sure if you can then use your mobile to make calls from your car.
Another solution, much cheaper and reliable, get a 128GB pen-drive and partition it on your computer into 32GB chunks and place your music on that. Connect the pen-drive using the MMI USB cable in the glove box and each 32GB will be visible to the car.
If you still want to stream via your mobile then search for MMI bluetooth.
