Replacing wing-mirror indicator unit
Hi there
A brilliant driver took my wing mirror out this afternoon while driving past me.
Motors look good (mirror casing still folds in easily, and the mirror mount motors still move). I need a new mirror and a new indicator unit.
Does anyone know how easy the indicator unit is to fit yourself? I'm guessing it won't take long, or be too expensive if I get someone else to do it, but if its easy, I might as well do it myself!
Thanks in advance.
M
Thanks in advance.
M
It is quite straightforward. You don't need to remove the mirror assembly from the car. Just pop the mirror off and there are a number of screws and a few electrical connectors to get it out.
I had to do so a few months ago and when you get he mirror off it becomes quite obvious how it comes apart.
mattjd247 (06-16-2020)
Thanks! I don't even need to worry about popping the mirror out because the force of the impact did that for me (and smashed the mirror into a million tiny pieces...). So no special tools etc required then by the sounds of it?
