CL-Class (W216) 2007-Present: CL 500, CL 600
Im sure this has been posted 400000 times but I need advice on suspension
Old Mar 26, 2021 | 07:16 PM
2014CL600's Avatar
Cars
My CL550 is perfect except for when I turn the car off, the front RH strut makes a series of electrical sounds and drops 1/2", then drops again another 1/2", until the height settles at 28". The rest of the car stays at 29". Is the sensor defective? It doesn't go any lower and I know it isn't leaking. Is this a sign of a defective sensor? When I start the car, it levels out perfectly. Is it a the sensor or the computer that controls the pump? It stays exactly at 29" until I lock the door, then it does it's lowering dance. Please advise.
Old Mar 27, 2021 | 07:54 PM
BenzNinja's Avatar
Former Vendor
you can keep guessing and swapping things but you can also solve your problem the normal way
with a diagnostics tool
Old Mar 28, 2021 | 10:47 AM
2014CL600's Avatar
Cars
Thanks for trying to sell me a product but no thanks
Old Mar 28, 2021 | 02:33 PM
Farfalho's Avatar
CLK 230 Kompressor
A simple OBD2 scan tool can help detect for erros. However, Star diagnostic should give details on the issue.
Also, consider a proper title describing the issue. Otherwise it becomes hard to track of bring people to know what kind of assistance you need.
Using the search tool is also recommended if you believe for this question have been asked that amount of times.
Old Mar 28, 2021 | 03:05 PM
BenzNinja's Avatar
Former Vendor
don't bother
He will learn by himself
