07 CL500 strange power issue
2007 CL500 5.5 W216
So my cars been off the road for about a year due to a bad crank sensor and time + money to fix. So I decided to get it done finally .
Being that the cars sat idle for a good solid few months I pulled my other car round and jump started it after filling it with some fuel from a Jerry can.
Quickly removed jump cables and let the car run for prob about an hour + to get the batteries enough charge.
However I now have this weird issue that many others have with the clock and date settings not sticking , but the difference is with mine the car also won't "remember" some other settings , when I turn ignition off the screen in the dash goes off instantly while the dials are still at their last readings and it will for example default back to S mode from comfort , reset the clock and date and sometimes language to German. To add to this If I leave the car for a while locked when o return both key fobs won't unlock the car I have to manually use the mechanical key to enter , once it's started the fob works fine again until I leave the car off for extended periods.
I've disconnected both batteries , reset command but nothing seems to fix it , the battery has enough power to start fine and even cleared a traction control fault (due to low voltage) does anyone have any suggestions?
