57k miles 07 CL550 Driver Seat Gremlins and more
Command will also not make my dash clock adjust. Clock works but when I enter the time in command, the clock does not reflect the updated time. The clock functioned fine when the car arrived and I set to my local time zone. After replacing the systems battery, I noticed I could not re adjust dash clock face. When I press the controller for command on the time, it just goes back to main time screen menu.....
Driver door handle not recognizing the fob on approach. I cannot tap the handle to lock either. Passenger works fine so antennae is working, guessing something worn out in the handle itself and most likely covered in the forum somewhere, newbie looking for the quick strike on the short list (for now)
Thx
this was the day I got the shoulder bags to deflate, you can see the leather was stretched like a tight bra for quite a while! Its much better now : )
Just curious...how was the extended warranty "flexed"? What parts were installed? I've got an extended warranty, and about the same mileage, so curious of what may happen in my near/medium term future.
I downloaded the firmware update from a dodgy eastern European forum since the original poster took it down, burned it to a CD, and installed it. Fixed all my clock woes. You could also get the dealer to install the GPS firmware update but they would charge you money for it.
