Jack Point
The biggest problem with doing brakes is your "automatic" parking brake. I did my rears by having motor running and transmission in N ... this electrically releases the parking brake. (There is a drum on back side of rear disc that serves as parking brake) Obviously wheels on ground blocked to prevent roll away. On these cars, parking brake is automatically electrically applied whenever ignition is off. It may be possible to disconnect wiring at the rear, but I couldn't get it, so did my workaround.
Note also that removal of caliper carrier from hub is required to remove the rotor, and Mercedes specifies those bolts be replaced, not reused. Torque for these bolts is something like 180nm, so a struggle to loosen and retighten, especially with vehicle close to ground on jack or jack stands as opposed to up on a lift.
