Hello, I would like to know how I can charge the batteries, with a charger, without damaging anything. I have seen several terminals, but I don't know whether to connect to the starter battery, and thus charge both, or you have to charge them individually. Thank you! (attached photo from the internet, which is like my cl500 from 2007)
Thanks for your answer, but I wanted to say where do I connect the charger clamps to charge the two batteries (the one in the trunk and the one in the engine starter)
apologies, I misunderstood.
In your pic, there is a brass looking plain post under the cover you popped off. That is the positive for the battery behind the rear seat. If you look at the front of the passenger side shock tower, you will find a ground connection. That is where the negative cable connects.
You will need 2 of these, one connected to the start battery and the other connected to the two other connections:
I leave my CL600 connected this way and I never have a starting or running issue. I also have 12 of my other cars connected to these chargers/maintainers as well as my tractor. They just work.
See ya
Thank you very much for answering, your answer has been very helpful. Now I can safely load it. regards!
