CL-Class (W216) 2007-Present: CL 500, CL 600
Please help CL500 2011 blue efficiency facelift
Old Jan 4, 2026 | 04:55 AM
dadavid1's Avatar
Hello guy i need some help please my mechanics in my country dont know whats the problem with the car
only when the car sits overnight or sometimes two three days ignition goes into number 1 number 2 but doesn’t crank like I didn’t press brake then i try with key first it crank after few times it stopped working with key also. Now it start sometimes after few tryis and check engine light come on with bunch of different codes ( attached pic) we changed both batteries aux and main. And still the same Mechanical we only found leaking camshaft sensor into wires we will changed them all.
NOTICE. BEFORE WE CLEAR FAULTS ECO SYMBOL STAYS YELLOW DOEST TURN GREEN
AFTER WE CLEAR FAULT THE ECO TURNS GREEN AND CAR DRIVES PERFECTLY NORMAL UNTIL ITS COOLED COMPLETLY AND THEN AGAIN NO START NO CRANK AND CHECK ENGINE COMES ON
Old Jan 9, 2026 | 04:09 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
This is over my head, but you might want to post this in the W221 forum which is larger and more active. The few of us with W216's usually post over there, since the cars are nearly identical minus two doors.
