CL-Class (W216) 2007-Present: CL 500, CL 600
ABC High ABC Pressure Line Bracket at AC Compressor--Need Photo
Old Mar 24, 2026 | 05:24 PM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
I'm finishing up a winter project, and have run into an unexpected problem. The ABC high pressure line is kept away from the fan belts by a bracket, with two C hooks on it for the power steering line and ABC line. I cannot figure out how to get it oriented correctly. The ridges around the bolt hole mean that the bracket will not sit flush against the timing case/ac compressor. I thought I might have it on backwards, but I don't think so. I know it has to be above the belt, despite the photo showing it below. Can anyone provide advice or a detailed photo of what the installed part looks like? It is the sort of thing that will be obvious once I get it clicked in correctly.
