Engine fan unexpectantly runs at max
Engine cold, not running - Fan activates, full max, when open trunk, unlock door happens again, runs for about 2 minutes, shuts off
While driving, temp normal, fan suddenly activates, full max, shuts off a few minutes later.
No pattern, just activates, regularly at full max speed.
Information: There is no fan relay, fan control module ok, coolant temp sensor, ok - A/C sensor ok.
Any insight appreciated, just spent $800 and got replacement thermostat that seemed to e ok
Fan problem remains?
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Are you doing the work yourself, and do you have Xentry? If doing the work yourself, my strategy is to replace all parts that are old--you are going to need to eventually anyway--and see where that gets you. If you have Xentry, you may be able to track down the odd electrical behavior. If you don't have Xentry or at least a high quality OBD reader, you are going to need to get one.
I vaguely remember something similar happening to my CL when I cleared some codes with the engine not running…try running the engine, re-scan for codes and clear again. This happened to me many years ago so I’m not sure but I think this may help.
https://mbworld.org/forums/s-class-w...ml#post8647419
It did help a previous member, and myself so I figured it was worth a try
