Adjusted Front Ride Height...Fresh Pics
CL kit from Carlsson
As is...still a fantastic looking ride!
Car looks great. Carlsson body kit is old... it is for a non-AMG CL, and to me there is only one kit that looks good on the CL other than the factory AMG kit.... that is Kleemann (which is what Lars has). But it is very expensive, and I would not put it on a CL that already has an AMG kit. I would do it if I had a standard CL.
I think your car looks great as is... hoenstly... I wouldn't touch another thing... its beautiful.
. Yes they are 20's but I do not have any rubbing issues at all...I think the wheels are 20x10 in the back.The car came with adjustable front linkage....The arm is in 2 peices and you just loosen the nut to colapse the bracket to lower it and seperate the peices to raise it....Only took about 10 minutes.
I think they're those rims.
I have some advce for you... that wheel is about to be discontinued. If you bend one, and you very well might as it is a 20", you will have to buy 4 new wheels. I would buy a 5th and keep it for just in case, buy a front as you will most likely bend that one, and you can change the hub and make it a rear since is a multi-piece.
and yeah... photos first, coors light second. If you are driving a CL you may want to upgrade from Coors Light to something a little higher-end... :p
So you throw away 3 perfectly good wheels and buy 4 new ones. It sux. Now I always buy a 5th when I know they are about to be discontinued. Even if you sell the car its good to give the owner a spare.
