CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
V12 generally sluggish from idle to 2000 rpms??
Old 08-09-2014, 03:50 AM
bentleyboy's Avatar
CL65 AMG W216, Bentley Continetal R Le mans, Bentley Turbo RT, BMW 735 i, CL65 AMG w215
I forgot to say that I've been chasing this problem for a year now and had the intercooler pump changed by MB but occasional misfire still there...I'm looking at a 216 instead but it will break my heart to get rid of my beautiful 215 65.
Old 08-09-2014, 02:15 PM
Welwynnick's Avatar
2006 S600
Sounds nlike what mine has been doing.
Does it jerk when you accelerate, then come off the throttle suddenly?
Nick
Old 08-10-2014, 04:02 AM
bentleyboy's Avatar
yes, and that's why the amg guys at the local dealers thought it was rear subframe front mounts. My cars done 44k and I drive it quite respectfully, no tyre burns.
Old 08-17-2014, 02:54 PM
Welwynnick's Avatar
2006 S600
I found that my problem was caused by a failed diverter valve. Not sure if that's what you're seeing.
Nick
Old 10-05-2014, 06:04 PM
bentleyboy's Avatar
jerkiness and misfire
Purely by chance and some illness I had run my tank low on fuel to virtually dry..I always carry a gallon in the for other folks really but I used it myself and then refilled...that cured the occasional misfire so I guess it was some water in the fuel some time ago which stayed in the tank.
The other problem with the jerkiness disappeared after I found out that I had a blown bulb in the traction control switch and had the ASR switched off.......switched that back on and different story but by that point I'd committed to the 216 which I have to say drives like silk.
Quick Reply: V12 generally sluggish from idle to 2000 rpms??
