Mb Lawsuit
You did not have it when it was new and MB does not buy cars back for a squeaky suspension. The problem seems very minor and most legal situations that get though involve safety systems etc.
I would look for a competent dealership instead of trying to go to court. I have seen people do this many times and more often than not you go home empty handed.
It is 100% fixable so just get to a tech that can figure it out. That would be the best use of time.
Looking at the service logs, My A/C would quit working, they would replace the pressure sensor (suppose to sense when freon is to low) thinking that there was no way it could be low on freon and that the sensor had gone bad, when the actual problem was that the evaporator core was leaking at a small enough rate that it could not be located.
To replace the pressure sensor, they sucked down the system, and then recharged it. The leak was small enough that it would still show to maintain a vacuum over several hours, and so the remedy was always to replace the pressure sensor.
After it was out of warranty, I found out from a Mercedes Benz Mechanic that Mercedes Benz knew that there was a problem, but didn't know what it was for several years. They were told just to keep "topping" the system off with a recharge.
It has always been my opinion that Mercedes Benz owes replacing the evaporator core for not just me, but all owners who had this problem while they were under warranty. Especially since the problem happened under warranty, and they only provided a band aid solution by topping it off with freon to keep it looking to be ok.
My car hasn't been driven on a warm day for several years now because charging it lasts for about 4 hours of A/C now.
How Mercedes Benz got away with this is still beside me. For the past several years I have been told that they will take care of it for me when the "good will" they are afforded by MBZ of North America is in the "green", but it has been several years now and I seriously doubt it will ever be done.
Then there is the depreciation for mileage. If you document the problem early, such as I did at 1300 miles, then in CA they deduct $0.10 per mile driven. I got a new car after at 36 months for only $1300.00 Not bad.
Sounds like a legal scam. Most attorneys promise you everything- They require a retainer of a couple of Gs and then say they tried their best but lost.
Do your homework before signing on the dotted line with any attorney.
Good Luck.
Good Luck.
If you really want the creaking fixed and it's remains under warranty -- Contact MB regional service manager. That's what he is there for. He will asssit you at the Dealership level.
I'd really be surprised if MB turned thier back on your problem.
You might want to post this issue on AMG Priviate Lounge.
Keep us informed on this issue.
You have got this creek issue on 2 threads in here.
You have a warranty. You just have a toad for a dealer.
Sounds like the dealers in NJ are not very bright.
Neither is Miss New Jersey from what I saw on the Today Show this morning.
Try one in New York or PA.
Its the ball joints. Ask them to put a little lube on them.
Bet it goes away. Ask nice and they will replace them under warranty.
I noticed you say they replaced them. I think they are not being truthfull.
GO TO A DIFFERENT DEALER. Find an SA familiar with CL`s.
Above all. Be professional and business like !!!!!
Tell them you are getting an attorney and they are just going to
let you twist in the wind. Remember this is not a safety related issue.
Its more cosmetic. YOU HAVE NO CASE.
