Tire Fitment
The Renntech promo CL55 had 255/25 on front with 295/30 in back on 19x9/19x10. However, that works out to roughly a 26" tire (the stock 275 on 18" comes in at around 26.7").
The Renntech offset effectively pushes the fronts outward for suspension clearance, and pulls the back in for fender clearance.
I'm guessing you have the AMG 18x9 in back (has an ET44). For reference, you can bolt this on the front and see that the inside is tight to the suspension but there is fender room that can be used if the rim was further out (lower ET number). I don't recommend driving the car like that though. Might work, I just haven't driven it that way.
I have ET 36 in front, and I believe I can go as high as a 26" tall 275 in front. But I wouldn't advise others to try it.
You can google "Renntech wheels.pdf" and find sites that have Renntech's pdf file posted that shows the offsets by rim and car model.
