CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Wanted: Stock 06 S65/ 05-06 CL65 wheels
Old Jan 31, 2008 | 01:12 AM
SGC's Avatar
SGC
2006 CL65
Wanted: Stock 06 S65/ 05 - 06 CL65 wheels, with or without tires.
I believe offset is ET44 front, ET60 rear.
Thanks.
Old Feb 4, 2008 | 08:24 PM
BiTurboAmg's Avatar
SL65 AMG
I am not sure offset but I know the wheels off the s class, and sl class both fit the same cars. I have a set of wheels off my sl65 I will sell w/o tires.
Old Feb 5, 2008 | 12:56 AM
SGC's Avatar
SGC
2006 CL65
Thanks. Can you check the offset on back side of the wheel. Should read ET and a number. I didn't think sl and s were the same; however, I could be wrong. I thought cl and s were the same.
What do you want for the wheels? PM me with a price.
Thanks again.
Old Feb 5, 2008 | 08:42 AM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
CL and S are have the same offset. SL is different.
Old Feb 12, 2008 | 01:06 AM
SGC's Avatar
SGC
2006 CL65
Thanks.
Any help finding these wheels would be appreciated.
Thanks.
Old Feb 12, 2008 | 06:17 PM
PeteCL55's Avatar
01' CL55 AMG, 86' 560SL
Here you go...
http://cgi.ebay.com/ebaymotors/19-NE...spagenameZWDVW
Old Feb 14, 2008 | 12:46 AM
SGC's Avatar
SGC
2006 CL65
Originally Posted by PeteCL55
Thanks Pete. Alot of scammers on ebay. Those wheels have the wrong offset for a cl65. The rear is supposed to be 60mm and those are 46mm. Thanks anyway.
Old Feb 14, 2008 | 12:56 AM
PeteCL55's Avatar
Double check your specs... I think these wheels are the correct offset. The fronts should be 19" x 8.5" with 44mm offset, and the rears should be 19" x 9.5" with 46mm offset. The S and CL share the same offset. The SL, E and others have a differnent offset.
Please don't take my word for it as I am not 100% sure (I THINK I am correct though)... I would call the dealer to make sure.
Pete
Old Feb 14, 2008 | 01:12 AM
SGC's Avatar
SGC
2006 CL65
Pete
Thanks Pete
It is my understanding the rear differential on the 05-6 CL65s is wider than the basic S and CL. As such a 60mm offset rear wheel is required on the 65s. That is what the dealer advised me and that is the wheel that was on the rear of my 06 s65. If I am wrong, let me know. I believe the non-65 S and CL have a 44 or 46mm offset rear wheel. Thanks.
Old Feb 14, 2008 | 01:20 AM
PeteCL55's Avatar
Thanks Pete
Hmm... that's interesting, I didn't know that the differentials were different. Well... good luck and I'll keep my eyes and ears open for you.
Old Feb 16, 2008 | 02:13 PM
SGC's Avatar
SGC
2006 CL65
Thanks.
FOUND A SET.
THANKS.
