CL55 On the Dyno!!
CL55 On the Dyno!!
393 stock dyno
422 After KLEEMANN stage 1 tune and boost kit
465 After 80 mm TB and Renntech I/C pump
Stage 2 KLEEMANN tune and headers should be completed on the car by this Wednesday. I will dyno again after the headers and tune are completed.
Way to go Ripped.
I'm told you should put a couple hundred miles of hard driving on the ecu before the dyno. However, if your last dyno came immediately after the mods, then follow the same method so you're apples are apples.
Good luck on the new numbers.
