Impact on performance due to wheel weight/size?
Also, how heavy is the stock rear '03 CL55 wheel+tire?
Thanks guys.
I have dynoed a lot of cars when switching wheels. Figure about 15-20 RWHP.
More importantly, if we know the time history of the torque at the wheel, then we can compute the acceleration as follows from Newtons laws, Net_Torque = Inerita_of_Wheel?*Angular_Acceleration.
Then, what we really care about is translational acceleration which is just: Trans_acceleration=Radius*Angular_acceleration.
Below is a graph that I generated using some dyno numbers I dug up online for a stock '03 CL55. It compares Trans_acceleration of a 70lbs wheel+tire to a 50lbs wheel+tire.
I know for a fact that these numbers mean nothing as far as Acceleration comptuation is concerned. The reason being is that I don't know if the torque numbers are given for just one wheel or the entire rear setup (2 wheels / axles). In my calculations I only used inertia of one wheel, which I doubt is correct but gives you a back of the napkin type calculation.
Then certainly, in real life conditions, the net torque is not just what the dyno graph reads, we also have to account for friction between tire and contact surface if nothing else..?
Maybe a better way to calculate acceleration would be to use torque readings along with horsepower readings. Dividing hp by torque would give us velocity and then we could differentiate to obtain acceleration? Would be more realistic and we wouldnt have to worry about detailed modeling since we have empirical data.
So how 'bout them Celtics?
Thanks guys.
Your car will accelerate better, but you will really notice how much more crisply the car turns in.
