CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
20" on new CL - what tire sizes?
Old Nov 24, 2008 | 01:42 AM
duc&tlrsammy's Avatar
Benz and Beemers
What staggered 20 inch tire sizes are you supposed to go with on a new CL? Will a 245-35-20 and a 275-30-20 work?
Old Dec 3, 2008 | 12:55 PM
HIGH-VELOCITY's Avatar
CL55
20's
Depending on where you do most of your driving your main area to watch is the aspect ratio. Most sizes will fit, but will you be able to tolerate the ride.
I found 25 and 30's were nice when I was in Vegas but unusable in the midwest.
Old Dec 3, 2008 | 09:09 PM
jicl55's Avatar
2003 cl55 (sold)
I'm running 20X9 on 255/35 in front and 20X10 285/30s in back. No problem when stock, but after i lowered it, had to roll the fenders cuz there was some rubbing. (On lorinser RS6s). Like the 35 30 setup due to potholes and crap.... don't want to buy more new rims...... wait a minute.... do u drive a cl55 or a cls55? May be slightly different.... i'm talking cl55 from my own experience..... cls55, i'm not so sure....
Old Dec 3, 2008 | 10:11 PM
Patentmat's Avatar
10.5s in the back, with 305/25. Car is lowered about 1.5 inches so it can occasionally rub on the freeway when the car drops further, so I generally just hit the button to raise the car up and that makes it go away almost completely.
Old Dec 3, 2008 | 11:17 PM
jicl55's Avatar
2003 cl55 (sold)
okay... i'm jealous as f**k
Old Dec 3, 2008 | 11:41 PM
URnext's Avatar
SL55 AMG
I'm running the following:
Front: 20X8.5 wheel 255/30/20 Tire
Rear: 20X10 wheel 295/25/20 Tire
No issues, but make sure you get the right offset to avoid problems regardless of wheel/tire size. Also you should try to keep the same the same tire diameter, see attached link:
http://www.miata.net/garage/tirecalc.html
Old Dec 4, 2008 | 06:41 PM
Benz and Beemers
Wouldnt a 255-30-20 and 295-25-20 be too small for a new body CL?
Anyways here is what I did to this CL63. Took of the 22's, than put the 20's on. The owner got rid of the stock wheels and needed to put 20's back on it inorder to sell the car.
It went from this.
22x8.5 and 22x10.5
245-30-22 and 295-25-22
To this
20x8.5 and 20x10 32et front and rear 12mm spacer in the rear to clear the caliper.
255-35-20 and 275-35-20
No rub.
Thanks for the ifo guys.
