CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
lowering 2003 cl 55
Old 02-23-2009, 02:17 AM
LILG's Avatar
SL500
Originally Posted by brokenstunter
Do a search on the CL500 forum for lowering. I did mine for less then $80.00 and its fully adjustable manually without even removing the wheels.
Ill get some pics on here asap
PICS???
Old 02-23-2009, 03:44 PM
brokenstunter's Avatar
2003 CL500
Haha, sorry forgot. Ill put up 2nite.
Old 02-23-2009, 06:00 PM
2003 CL500
Here they are
Front wheel lowering link
Rear wheel lowering link
Rear lowering link
Factory front link
Lowering links installed with ABC fully raised
Lowering links installed with ABC fully lowered, 2.5' drop from factory is where I set mine. I can go all the way to the ground with the few turns of a couple 10mm wrench's.
It will rub oh so slightly if the ABC is fully lowered and your over the speed that the car lowers itself. I just lift up the car with the ABC and never had any problems yet. My car is just a cruiser so I never go fast anyway so this suits my needs perfect.
Old 02-24-2009, 03:55 AM
LILG's Avatar
SL500
I made my lowering links for my SL tonight, all went good just need to adjust two links for the right height. $50 and two hours. pics tomorrow
Old 02-24-2009, 11:13 AM
fatmike's Avatar
CLK63 BS
At first I had links, but I wanted to go lower with the ability to adjust the height whenever I wanted. Now I have a RENNtech module w/ controller on top of my links. The module also controls the auto-lowering at high speeds. I would recommend a module for a decent drop with high adjustability.
Old 02-24-2009, 02:16 PM
2003 CL500
Thats next on the list but I had to get the static hieght where I wanted it first because the module doesnt go low enough on its own.
I didnt know that the Renntech also controled the auto lowering as well. Thats pimp.
Cant wait to lay this ***** down over the new wheels with the Renntech.
Old 02-25-2009, 01:28 PM
  #32
LILG's Avatar
SL500
LOWERING LINKS ? - look at this post for pics
Old 02-25-2009, 02:24 PM
  #33
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Originally Posted by chino702
whats the best way to lower my benz???
Let the tires down!!
Sorry feeling devilish today.
Old 03-26-2009, 07:41 PM
  #34
Hardeep's Avatar
CL55 AMG (215)
If you put 20"wheels on the car do you HAVE to lower it ? Or can you just leave it as is??
Old 03-27-2009, 01:06 PM
  #35
D-5
D-5's Avatar
2003 E55
I have 20" wheels on my car and its lowered. By reducing the gap between fenders and tires, the car looks much much better.
Old 04-26-2010, 05:27 PM
  #36
lionking30's Avatar
2003 CL, 2008 SL 500, 2007 BMW, 2005 Prius
allot of people say the rear are adjustable from factory, but when I look at my 05 S55 and 03 CL both look pretty much like the front rods?
nothing to adjust, front washers are easy how about the rear's any pics or advice would be appreciated.
Thanks...
Old 05-03-2010, 09:14 PM
  #37
rchoe618's Avatar
W215 CL65 & w221 S63
just ordered 20' wheels for CL65 (w215) with 285 / 30 , and also ordered lowering links. Planning to lower it 1 or 1.5 inch , Will it rub or any problems with this set up ?
Old 05-07-2010, 03:07 PM
  #38
sunpointair's Avatar
2003 CL55
I just put new wheels and tires on my CL55. I have ISS Forged 10.5 " wheels on the rear with 285x30x20. They hit once or twice when I first put them on, I have not had any problems since.....I am running stock height. I like the way it sets !
Old 05-24-2010, 09:07 PM
  #39
rchoe618's Avatar
finally got the wheels from symbolic cv15 20x10 with 285/30 and rubbs after lowering it 1 inch. sent it back to make it 20x9.5 with same tires and hopefully solve the problem.. any offset and tire recommendations ? flat look from fender, not to stick out or sucked in from fender
Quick Reply: lowering 2003 cl 55
