CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Out dated phone...
Old Jan 21, 2003 | 01:44 PM
BLKCL55's Avatar
2005 G55
Thumbs down Out dated phone...
Having a 2002 CL55 with the outdated "Timeport" phone, I was wondering if anyone has any idea as to how difficult, or expensive it would be to upgrade to the Motorola V60?
Cheers
Old Jan 21, 2003 | 02:57 PM
awiner's Avatar
2003 CL55 AMG
It is actually very simple. A new PSE, cradle and cord kit is all that is needed to be replaced. A new v60 handset as well of course. 10 minute job. The v60 handset is approx $500 retail and the PSE is probably about the same. Craddle and cord kit runs approx $180 retail.
Old Jan 21, 2003 | 05:00 PM
BLKCL55's Avatar
2005 G55
Question
Thanks awiner, but I was under the impression that our phones had some sort of "chip"from Mercedes inside them so it could integrate and interact with the car's computer.
Is this not the case?
Old Jan 21, 2003 | 05:19 PM
BLKCL55's Avatar
2005 G55
Sorry, one more thing. What's a PSE?
Old Jan 21, 2003 | 05:51 PM
Smurph's Avatar
CL65 2005
The V60 Phone is a "special" from Mercedes. I also had to specify the carrier that I wanted as there seems to be a difference from Cellular One to Verizon to whoever. In my old 2001 CL I bought a second Timeport and it would not work when pluged into the car system.
Question?? With the old Timeport I was able to be alerted to a voice mail message waiting with a series of tones when starting the car. With the V60 there is no letting you know that a message was received. Is there a something I missed in setting up the V60?
Old Jan 21, 2003 | 08:59 PM
awiner's Avatar
2003 CL55 AMG
I should of posted that you WILL need a MB V60. You can not use a normal V60 and have integration. PSE stands for phone support electronics. The PSE is the brains of the phone system and is mounted behind the left rear trunk liner of your car.
Old Jan 22, 2003 | 01:38 AM
BLKCL55's Avatar
2005 G55
Thank you again, awiner. Off to dealer in the morning...
Cheers
Old Jan 22, 2003 | 02:27 AM
awiner's Avatar
2003 CL55 AMG
Cheers
There is a 'upgrade' kit. Ask your dealer. This upgrade kit is at a reduced price supposedly.
Old Jan 22, 2003 | 07:26 PM
smc22's Avatar
2017 S63 Cabriolet Black With Porcelain 2019 Range Rover Velar Special Edition
vioce mail ?
awiner I have a cl500 v60 phone verizon service how can you tell you have voice mail. my 2002 s500 had a little envelope in the right corner of the screen . In this car the only way I can tell is when you have the radio on every couple minutes it has a brief pause in the music sure enough when you open the hand set in the arm rest it tells you otherwise nothing let me know thanks........
Old Jan 23, 2003 | 08:12 PM
awiner's Avatar
2003 CL55 AMG
Re: vioce mail ?
Unfortunately, the only icon you will now get via COMAND is the icon when you have a SMS text msg. No voice mail icons as Mercedes says there is too many voice mail indicator formats to support. Sounds like BS to me.
At any rate, you can go into your phone and enable a sound alert when you have voice mail so you get that instead of the "mute" every few minutes. That is the best alternative thus far.
Old Jan 23, 2003 | 10:06 PM
smc22's Avatar
phone
thanks for the info.......
Old Jan 23, 2003 | 10:37 PM
BLKCL55's Avatar
2005 G55
I'm going in on Saturday and picking up my new V60 phone, cord and cradle. Apparently, (and this is what I was told) there's no need for a new PSE. The phone, cradle and cord are the only parts required for the upgrade, and they will plug into the existing 2002 system without a hitch... I hope Mr. Parts Department is right, I'd hate to find out he's wrong while I'm sitting in the waiting room having the cradle and cord installed.
Cheers and thanks, awiner.
Old Jan 23, 2003 | 10:59 PM
awiner's Avatar
2003 CL55 AMG
Sometime in 2002 Mercedes changed from the old PSE to the new Dual PSE. Therefore, I hope your Part's mgr. verified you have the dual PSE (With blue label) vs the older PSE (With white lable).
Old Feb 1, 2003 | 03:02 AM
BLKCL55's Avatar
2005 G55
Update:
Picked up my new MB V60 phone, with cradle and cord. Had the PSE upgraded. Everything works well, except that no one can hear me at the other end of the phone...argh
Will have to go back when I can leave my car so the service Dept. can figure out the problem. More at eleven...
