CL600 offset
I am looking at buying a CL600 and was wandering what the bolt pattern is on these cars and what the best offset is? Just want to see if my 20" Mrr rims from my e55 will fit this car?
Using them as is will cause them to "poke" outboard by 1/2". If the car's not lowered they will probably fit, but your steering geometry will be wrong up front (the steering axis will not have the correct relationship to the tire centerline) and the contact patch in the rear will be wrong. This will affect steering feel, stability, handling and tire wear.
Would you be happy if any other of your alignment settings were dialed in 1/2" off spec by a shop?
